brass water gauge adaptor for engine (male-male)
Welcome to the Allard Owners Club. Forums Technical Talk brass water gauge adaptor for engine (male-male)
Viewing 2 reply threads
    • #7312
      Charles GoughCharles Gough
        Hello Ben, It looks like 3/8 BSP both sides. I put the vernier on it to check and it came out at 0.65″ ish and the book for 3/8 BSP is 0.656. My gauge is a smiths unit so it should be the same but check anyway. As for the quarter light rubbers I think they were a one piece L section part that was made to fit the quarter light opening. I will check and look up some old pictures. Window rubbers for our cars are virtually non existent , I am fast approaching needing a complete set but no one does our sizes. I will check on what the quarter light should be, kind regards, Charles Water temp to head
      • #7307
          Hello Ben, do you mean the the the thread that is in the cylinder head, next to the hose outlet to the radiator. I do not think it is the block, it is only drain taps fitted down there. 3/8BSP rings a bell but I will have to check
          Kind regards, Charles
          • #7309
              Sorry yes, that’s exactly what I mean!  If you or anyone knows what the other end is too that would be fantastic!
          • #7299
              I need to buy a male to male adaptor to fit my smiths water gauge sensor to my 24 stud flathead and believe it’s a BSP thread in the block maybe?  Does anyone know what size thread it might be, and also what the thread on the gauge fitting is most likely to be?
              I’m guessing it’s something like this:
              https://www.ebay.co.uk/itm/121015302212?hash=item1c2d12f844:g:Q6UAAOxyUgtTOq7m
              • This topic was modified 1 year, 4 months ago by Ben StevensBen Stevens.
