The ‘Allard Special’ at Bicester Motor Shed
Welcome to the Allard Owners Club. Forums Technical Talk The ‘Allard Special’ at Bicester Motor Shed
Viewing 12 reply threads
    • #7609
      Des SowerbyDes Sowerby
        For colour I’ll summarise the two stories I heard about this car’s provenance. NB whilst I was researching what had happened to the pre-war Allard Specials I came across a number of conflicting stories for different cars, part of the fun being interrogating these stories and picking what (or what combination) seemed to me to be the most likely.
        Graham is clear that following up a postcard in a newsagents window he bought the car, covered in cobwebs, from a lockup garage in an unsalubrious part of Cambridge – the seller saying he had bought it from Adlards at the beginning of the war.  Graham said it was registered as a 1947 Allard Special and he did not push its pre-war provenance though held it lightly as an interesting possibililty. He said it must be 55 years ago he bought the car (ie early 1960s).
        Many of you will know John Patterson who, as well as being generous in helping me with my car, has perhaps owned / broken / brokered more Allards than anyone else? He knows about and has stories about many Allards and “goings-on” in the post war period and over the years I’ve been amazed at his recollection of details in the stories he recounts. He knew about the car that Graham owned and in 2017 he described the following contacts he had had with the car.
        • Some 30+ years earlier, as an Allard afficianado, he had been called to the house of Sir Kit Martin (the Queen’s architect in John’s recollection) to see this car which was then owned by someone in the family [I traced a Sir Leslie Martin who lived near Cambridge and checked with John that this sounded like the same person]
        • Some years later John saw it again at Duxford Service Station and helped the proprietor by providing L type chassis plate and documents for the un-registered car. Apparently the car was used a few times then disappeared again. Presumably it went to Cambridge prior to Grahams acquiring it?
        • On both occasions John knew the car it had a solid Ford front axle.
          • NB in Graham’s garden was an Allard chassis without it’s Ballamy front end, so could this have been fitted to the car we are looking into?
        On checking John’s story with Graham, he was sure that John must be talking about a different car. Graham was going to send me copies of registration documents etc, not to hand when I visited, so we could see if there was any firm data to help us – but they never arrived.
        I sent Stewart all the information I had and he too was going to send be registration details, though they never arrived either, Stewart clearly having decided to move the car on.  Stewart said that whilst most of the car was clearly post-war the chassis was recorded as a 1938 Mercury chassis which seems a bit of a stretch as the Mercury was only launched in November 1938. So it will be interesting to me to see if any documents associated with the sale can shed any clarifying llight on any of these stories.
        Des
      • #7608
          Neil’s summary of the engine fits with the notes I took in 2017. Graham said he had made a number of mods to the engine, including a high pressure cooling system and mounting it below the normal hangers. I’ve a note that he had a spare French V8 crated in his workshop and I’m sure he said he had installed a French V8 in this car. He had a mechanic who visited to work on his cars every Wednesday.
          Another snippet is that he was very pleased with modifications to the chassis saying it was not only boxed in but also double strength – the inner “C” section fitting inside the outer chassis. He felt they had managed to transform the steering with this stiffening of the chassis, the lowering of the engine, installing a Watts linkage, modern dampers and using large 750 tyres.
          Des
        • #7606
          Tim WilsonTim Wilson
            Viz:
            • #7607
              Neil BennettNeil Bennett
                That’s an example of the last US production run of Ford flathead engines from 1949 to 1953, designated 8BA, with 24 cylinder head studs per bank and a capacity of 255 cu. ins. (4184 cc.) from its 3.3/16″ bore and 4″ stroke. Those engines were also made under licence by SIMCA in France for their military vehicles, and this engine has all the signs of being French – the cylinder head markings, the paint finish and the cast-in boss at the rear of the left cylinder bank which housed the governor and hour meter. The square black oil union looks French too.
            • #7605
                Interestingly, DVLA have LKX 520 as having a cubic capacity of 3,622 – which would suggest either an earlier American flathead – or a Ford Pilot – which it cannot be, since the cooling outlets for the hoses up to the rad. are right at the front of the cylinder heads… more thoughts, anyone? Tim.
              • #7604
                  I’ll try another upload… Tim.
                • #7596
                    Neil: l have Emailed you with a pic of Motor Shed’s ‘Mercury Allard Special’. I find it difficult to upload images onto the Forum. Cheers, Tim .
                    • #7598
                        Many thanks Tim. That isn’t the car I had thought, but here it is for others to peruse:
                    • #7595
                        May we see a photograph of this car, please?
                        “Previous owner for 68 years” strikes a chord. I may have some information.
                        Neil.
                      • #7594
                          I know this car a bit. It was most recently owned by Stewart Crouch who bought it ? 3 years ago from Graham Fuller.  I went to see it at Graham’s place in February 2017 during my researches for the pre-war boolet as Mike Knapman alerted me that Graham Fuller had a car that he (Graham) thought might be a pre-war Allard Special. As observed above it is a lovely car with lots that is Allard-like about it. Stewart contacted me during 2021 hoping I could support its putative status as a pre-war Allard Special, which I did not feel able to do. During this period I was contacted by EDS Motorsport asking for observations, though they never got back to me.
                          I wrote a note at the time of my visit and can add more details when we discuss the car in a Registrars meeting. But in brief there are two variant stories I picked up that day: one from Graham and a different one from John Patterson who I visited on my way home. Graham responded to an advert on a newsagents window and bought the car from a lockup in a seedy part of Cambridge, the seller assuring him it was a pre-war Allard. John Patterson recounts a series of earlier owners including coming across the car at Duxford Service Station where John  provided the proprieter with an L type chassis plate and log book so it could be registered after which it must have gone to Cambridge. Graham feels John must have been talking about a different car but John is certain it is the same car. Graham was going to send me paperwork but never did. Looking forward to the discussion…Des
                        • #7509
                            Ron: l now have some details of the mystery  Mercury-engined ‘Allard’ Special, currently for sale at Bicester Motor Shed.
                            Chassis no is H 54 204, and
                            Engine no: 51221 2. The vendor has owned the special for ‘a few years’, the previous owner owner having had the car for 68 years before that. It is said that during that lengthy period, the car has always had the identity of a ‘special’.
                            Hope this helps; regardless of its i/d, from the photos at least, the car looks really nice, to me. Tim.
                          • #7504
                            Ron DowleRon Dowle
                              If anyone can find out the chassis number, we can try a search through factory records,
                            • #7497
                                Thanks, Ron; l’ll await with interest, any further news. I’ve also Emailed Bicester Motor Shed, to see if they’ll offer more info. Tim.
                              • #7496
                                Ron DowleRon Dowle
                                  Tim, Mark Brett looked at it a couple of weeks ago, he is also trying to contact the owner. So far we have not been able to find any-thing about it in club or factory records.
                                • #7495
                                    Hi, all: the above car, for sale at BMS, was mentioned during a recent Social Zoom session. I’ve now seen the photos of the car; it looks rather nice and has a Mercury engine. Has anyone here had the chance to view it in the tin, or to chat to the vendor? It would be good to find out more on its provenance; l note that the blurb merely suggests that the car ‘could have Allard heritage’. Of course it sports an ‘Allard’ badge on the nose cone which proves nothing – but l can make out a Ballamy front axle. There seems little more to go on, other than that… Your thoughts, please! Tim Wilson .
