- This topic has 6 replies, 3 voices, and was last updated 2 years, 1 month ago by
Russell McCleave.
- 27 May 2022 at 7:33 PM #7305
Russell McCleave
ParticipantMe again.
Reverse, first and neutral super-easy to find and
select.
Second and third a little less co-operative.
Wondering if the linkage rod is supposed to be bent as per the attached photo ?
Or indeed if there’s another solution to make these two gears easier ?
28 May 2022 at 10:45 AM #7306Charles Gough
MemberHello Russel, I believe the small adjuster rods should be straight. Also check that there is no excessive play in the lower rubber bushes (the ones fitted to the gear change column arms). Any slack in this area will lesson the amount of movement the rods will have to engage a gear.
Hope the picture helps, kind regards Charles Gough
28 May 2022 at 11:57 AM #7308Russell McCleave
ParticipantThank you Sir.
28 May 2022 at 12:21 PM #7310Ben Stevens
KeymasterSince I swapped my gearbox for a modern 5 speed I’ve got this wall ornament in my garage which you could have if you like?
28 May 2022 at 12:34 PM #7311Russell McCleave
ParticipantYes please Squire. Away at the moment, I’ll call you on my return if that’s OK.
28 May 2022 at 1:44 PM #7313Ben Stevens
KeymasterNo problem, my number is in the year book which you should get in the post any day now. Ping me a message by WhatsApp / Text / Email and we can sort it out.
7 June 2022 at 5:19 PM #7324Russell McCleave
ParticipantThank you.
