- This topic has 0 replies, 1 voice, and was last updated 3 years, 5 months ago by
Ron Dowle.
- 9 February 2021 at 4:05 PM #5762
Ron Dowle
ParticipantOdd question, Has any one found a way to connect a remote hydrolic fluid reservoir to the standard master combined brake cylinder / reservoir on a K1. I want to fit a reservoir to the bulkhead and run a pipe down to the top-up cap by the brake peddle arraignment.
9 February 2021 at 4:42 PM #5763BartRatkiewicz
ParticipantQuite simple really. Drill and put a fitting into the mc cap and pipe it to the remote reservoir which shouldbe at a higher level than the mc normlly on the engine’s bulkhead.
12 February 2021 at 6:39 PM #5765Geoff Pinch
ParticipantIt’s a problem Morris Minor owners solve and I have used a kit for a Moggy similar to this one on eBay:
Having fitted it in future I’d replicate using quality components. Getting a good seal on the master cylinder cap and the new fitting is important but I’m sure there are elegant solutions that would connect to the pipe to the master cylinder cap without the plastic pipe heading straight up. On the Morris the floor was too close to allow a sweep for the plastic pipe and I used plastic right angle joiner onto a short piece of pipe to make it work better.
13 February 2021 at 2:13 PM #5766Ron Dowle
ParticipantMany thanks all. one or two ideas plus positive comments from last weeks social ZOOM. so Its off with the floor next.
13 February 2021 at 3:59 PM #5767Ben Stevens
KeymasterI’d be very curious to know how you get on as I’ll almost certainly want to fit something like this…once I’ve actually got some brakes to attach it to! So please do post updates on here, pictures would be brilliant too 🙂
